Wish your M1008 would turn like an M1009?
The FLU farm
1,319
The actual midwest, NM.
Well, you already know it is (was?) an M1008. Needed a stouter tow vehicle than the one I was using to pull a 10-foot dump trailer, which didn't really like pulling a full load of dirt.
Also wanted a yard goat of sorts.
The choices were to cut the sheet metal off the rear of my M1009 or shorten the M1008. The '9 would've been better in a way with its Atlas transfer case (allowing 2WD Low) and it already had 3/4-ton axles. But to have what's basically an abuse vehicle with a Banks turbo didn't feel quite right. So, sold the M1009 and cut down the stock M1008.DSCN0978.jpg Needless to say, as soon as the more capable tug was completed, a 16-foot dump trailer was purchased. Which the M1008 handles without any problems.
The FLU farm
1,319
Thanks, Willem. That's what UV can accomplish over time.
The mirrors are off of a friend's old Apollo motor home, with modified lower mounts and homemade upper mounts. Stuff I had laying around in other words.
Ilikemtb999
45
Denver, CO
So did you move the axle forward 31"? Would you be able to post some pictures of the leaf spring mounting points? This thing looks great
The FLU farm
1,319
No, the 31-inch shortening is a little misleading in that it includes both what I removed from the frame at the rear of the cab and behind the rear spring hangers.
In other words, the wheelbase isn't a full 31 inches shorter. I'll dig up some photos later today that might help explain what I did, and how.
Basically, the forward cut was based on how much of the frame could be removed (and reattached) with relative ease without removing the cab.
Then the drive shaft angle dictated that the two frame halves be a offset a bit. Well, I wanted to keep the factory drive shaft angle, and also not get the exaggerated rake that would've resulted from simply butting the frame rails up against each other.
Hopefully the photos will explain it better.
At this point I'm fighting the urge to put duals in the rear. It'd look bitchin', I think, but not be very practical for what I'm doing. A toolbox or two, somewhere to put shovels, etc. would be more intelligent additions. And a couple of cheap work lights, front and rear. And a winch. Maybe even taillights inset into the back of the cab.
Main problem being that I won't live long enough to make all that modifications to all the vehicles that I'd like to.
The FLU farm
1,319
Okay, found some photos that might help explain DSCN0296.jpghow I cut this one down. This was about as far forward, and definitely as far to the rear, that was feasible.
DSCN0299.jpgHere you can see the offset, allowing the drive shaft to stay at the stock angle. And prevent a cartoonish rake in the process.
DSCN0306.jpg Needless to say, the flanges were gusseted top and bottom, plus a plate covering the cut was welded in. Not pretty, and not only because of my welding skills, but there was some sort of coating (especially on the inside of the frame) that looked like melted solder dripping off.
DSCN0312.jpg To make it a useful tug, leftover 4x4 1/4-inch wall tubing was used to make a gooseneck hitch and a regular receiver. The receiver also serving as a new crossmember after I lopped off the now useless rear part of the frame. Which is also how the frame shortening added up to 31 inches, but the wheelbase didn't shrink by quite as much.
At some point I'll get around to build a box over the tank, which will be secured to the brackets that used to hold the tank.
Hope this sheds some light on how the project was done. It was fun to do, and made the M1008, err, 1007.2 very maneuverable and handy for pulling various trailers.
The FLU farm
1,319
I'm actually proud of myself for not having installed duals yet. Especially since I have a set.
Many, many other things that needs to get done, but now you reminded me of something I want to try, despite that it'll make it less practical. Thanks a lot, corelokt.
The FLU farm
1,319
I think it would add to "WTF, did GM make that?" factor.
One minor detail came to mind. The wheels I have are aluminum. That just wouldn't look right.
Guess I could put the aluminum rims on the inside and the black steel inners on the outside. Unless I have another set of wheels...gotta look.
The FLU farm
1,319
What's the easiest way to put dually wheels on a 14 bolt like ours?
Not that I've measured or tried, but it sure looks like it'd merely be a matter of removing the single wheel and bolting the duals on.
The only reason that I can see why it wouldn't work is if there isn't enough distance to the spring, which it sure looks like there is.
Keep in mind that while a dually pickup has the inner rear in the same track as the front tire, a cab and chassis usually puts the front tire's track right in the middle of the rears.
Which is just about what I would end up with.
EDIT: Measured a dually wheel just for kicks, and with a 235/80R17 tire it would protrude inwards about 10 inches from the hub face. That should leave around an inch of sidewall to spring clearance, and I think GM wheels have less offset than the Ram wheel I measured. Of course, with the bed in place and a single wheel axle it would require tubbed fenders and probably some trimming of the outer fender opening, like on a factory dually.
86m1028
17
Murphy TEXAS
The springs on a 1 ton are closer to the frame for this very reason.
The inner dual on a cc axle is very close to the ubolts on the springs.
Look at Recovery4x4 threads, He has put a cc 14 bolt under his m1031 (secm).
