WMO (again)
47to70
40
somerset ky
Have several totes that have been sitting for 5 years, been running the WMO through a 3 micron filter/water separator, only sucking off the top 50 gallons or so. Then refill the tote and it goes back to sitting for another 5 years. Thought that should be good to go but read here in an older post that gas needs to be added to really get it to settle. (1) Is that the consensus here? (2) If so, how much gas should be added to a 375 gallon tote to get the job done?
dmetalmiki
2,028
London England
FIVE years..? Wow!. That will clean enough' to go' as iz in my opinion, AND filtered? Gosh!..mor'an ready to go.
BUT, To get more bang for your buck..(Or ruble)..ANY amount (Not exeeding half (50%)). Would be the 'Icing on the cake'.
V8srfun
538
Altoona pa
From what I understood the gasoline just made the settlement faster. If adding to your totes that are going to be slightly drained and refilled I would use as little as possible so the percentage in the tote does not get excessive over time.
ToddJK
4,518
Sparta, MI
If you really wanna get rid of it, I accept free deliveries!
If you're giving it away, save yourself the time and money from doing anything to it. Gas helps but ultimately, gravity does the work and over time, the bottom is holding any particles missed when filtered.
ToddJK
4,518
Sparta, MI
47to70,
Did you see my post about free oil and diesel? 2 totes of oil and a 55 gallon drum of diesel. Free for the taking...
Gas helps but also keep vapors in mind. You'll want to wear eye protection whenever you remove the cap, but ultimately gravity has done the work for you. If you can get your hands on it, try out some jet fuel, not aviation gas but jet fuel, JP-5. Looks like clear Kerosene, mixes real well with wmo and runs much better than gas but that can be a difficult commodity to get.
