WMO and smoke
JCKnife
46
Kentucky
Now that I'm running WMO (somewhere in the range of 60%-75%) I pay attention and read all the WMO / filtering threads I see. Many of them talk about making extra smoke. If anything I notice LESS smoke with WMO than I did with straight diesel.
Anything I should be worried about?
Looks like my FDC is NOT bypassed (for what that's worth).
Josh
12
Portland, Oregon
Mine puts out a nice colum of blue smoke when its cold. Once its up to running temp the smoke dissappears unless I'm on the throttle. My truck doesnt burn the crankcase oil ( level hasnt ever droped in).
It defintalt smokes more now that I turned up my fuel screw, and my FDC is bypassed.
jrobinson5093
jakin georgia
I get about the same maybe a little less smoke in the morning. but it smokes more when it is hot. I run 100% wmo all the time. and it may be that the fuel is thicker and is not flowing as much so it dont smoke as much, but wmo has more BTUs the diesel so you get the same power on less fuel. but im no expert
sp00n
26
Huntsville, AL
I'm running 100% WMO and it blows a big cloud of blue smoke on startup and when its cold it blows a good bit of smoke. Once its warm its very light carbon colored smoke at idle and a normal diesel amount of smoke on the throttle. It blew a lot more smoke on #2 diesel, doesn't make sense.
hdmax
new Lexington, Ohio
Have you cleaned the air cleaner lately? A clogged/dirty air cleaner will cause the truck to smoke, as it is not getting enough air to burn the fuel, sending unburnt fuel up the stack! (Like when a diesel lags, it smokes more!)
