dstang97
- 30
- 48
- Clover, SC
I did tons of searching but no one mentioned this. Do you think a oil pump from a furnace would work to push fuel through a filter rack?
I think he meant "thirsty" for air. As in is has a high consumption rate.
I use a $40 harbor freight water pump and it warks great on the pressure side. Not so great on the suction side but I'm looking at redesigning my plumbing to see if I can get it to suck better.![]()
No worries. Got yer back.Your right, My bad on the typo, I fixed it![]()
Umm... there are actually two filters in that picture.I see you only have one filter. Do you pre-filter before that tank? Is the return to relieve some of the pressure?
More or less correct.Looks to me like he can use the same pump to circulate the fuel through the filter, or pump it into his fuel tank.
