WMO/WVO in a NHC 250??
Westech
CPL
6,104
207
cow farts, Wisconsin
When I was training a couple years ago I asked the guy why the 915A3 were smoking so bad. He said they use 25% Filtered WMO with JP8. it cut fuel cost a bit and lubed the pump and injectors.
alleganypellets
wellsville NY
Hoped I might get a clearer response to this old thread, I have a stationary NHC-250 that I want to set up a dula tank system on, I can heat the WVO to any temp needed and strain it or let Gravity work it's wonders, has anyone had experience with these? Sure would be good for the republic.
Paul
"If the American People ever allow private banks to control the issue of their currency, first by inflation, then by deflation, the banks and the corporations that grow up around them willdeprive the people of all property until their children wake up homeless on the contenent their fathers conquered- Thomas Jefferson
wreckerman893
Possum Connoisseur
15,618
2,013
You can run it mixed if the temp will not get low enough to cause the WVO to thicken......if so you can make a heat exchanger using engine coolant to heat the veggie up......crank on diesel.....switch to heated WVO (160 degrees is optimum) and run....switch back to diesel prior to shutting down.
There are commercial units with automatic switching valves or you can homebrew a system if you have the mechical ability.
