Working the Deuce...
rmgill
14
Decatur, Ga
So, I volunteer at the local Railroad Museum. They recently received a tank car (kaolin slurry) that is in very good shape. It was placed at the rear of building 1 some time back. They had a donation of a VERY well preserved late 40s fire truck that they need to make space for and they'll be putting it into the back of building 1. So, the tank car had to move to clear the door. The problem is that the leader to get to the tank car via the back of building 1 is VERY short.
So, enter me with my truck last saturday. They needed the tank car moved and I had the means. I used the large 3/4" chain with pear links to hook up. I bought this at the last GaMVPA rally and I knew it'd be perfect for moves like this.
I had to be careful 1, to move the car slowly and 2 to be certain I didn't run over any part of the track that had bolts or projections that would tear a tire. I managed to do both neatly and NOT have a problem. The lead that I was pulling the tank car up was very slightly up grade so there was no issue with the tank car running down the truck on the incline.
The truck had no issues, gradually letting out the clutch, a bit of gas to 1500 RPM and letting it ease into the pull and it started the car moving no problem. It even climbed the rails to get past two sets of switches no problem.
I'll be going back today to help move the fire truck into it's position as it's NOT running right now.
rmgill
14
Decatur, Ga
The guys with the logging and construction companies probably have that. The tank car WAS empty. It is however a double wall tank with a great bloody structure and trucks, I'll have to check it's tare weight later today. I didn't note that before.
saddamsnightmare
80
Abilene, Texas
December 22nd, 2009.
RMGILL:
Congratulations on the tank car pull.... Figure rolling resistance and 4 to 6 lbs per ton on level track-roller bearings and warm temperatures(?), probably not pulling 400 lbs rolling resistance. I used to move a 47,000 LB Nickle Plate Road C-7-P bay window caboose on friction bearings with a 1989 Ford F250. Starting's not the problem..... Stopping can be.
If you look in the book US Military Railroads by General Carl Grey (1955?) you will see that many deuces, including cab over GMC's, were adapted in Europe during WWII as switch engines and locomotives, and back in the 1970's one of the US Army bases in Korea had an M35A2 adapted to run on the rails with couplers and air brakes to serve as the base switcher. Now your boys need to get an ex USAF GE44/45 tonner, they can suck it up operating for about $300.00 in paperwork charges, mooch a DOD roller bearing flat for a few bucks more to haul it in on, and you have a two car train....:-D Unimogs are frequently adapted to locomotive duty in Europe, and I believe that the Long Island has one as a shop switcher.
Cheers,
Kyle F. McGrogan:-D
rmgill
14
Decatur, Ga
Kyle, the RR Museum, has two 44 tonners. Hartwell #2 and The problem is for this particular move it was a problem to get to this particular lead. The lead track beyond the points is just enough space for a single car and a track mobile (currently down). I don't think their 44 tonners AND a rail car will fit in this lead. It usually takes TWO locomotives to make the move. IT was quicker for me to use the deuce since I was there and they just need this one car moved clear of the doors to building 1.
I am going to ask why we don't extend this lead given they have some sections of track already made up.
Coal Cracker
Weatherly, Pa.
RMGILL:
Cheers,
Kyle F. McGrogan:-D
I would love to see a pic of a deuce or a 5 ton with a coupler and air hose / hirail setup, now I'm on a pic quest
tm america
24
merrillville in
nice job on the pull pics look great.i pulled i dead d9 with front loader about 1.5 miles in soft ground with my deuce when i got to where it was going it was sand i dug down to the hubs .i dont know how i was about to back out to unhook the chain.i used a 1 inch chain and had about 40000lbs of sand in the back put it in low and kept it going steady
dittle
72
Albia, IA
40000 lbs of sand?????????? Did you break your axels with that :p
Nevermind, re-read your post. Had it in my mind that you had that in your deuce.
Farmun
Ashland City, TN
My brother in law works for a railroad company. He got his work truck (one that has the rail wheels that lower to the tracks) stuck this past weekend. We used the Deuce to pull him out. Not quite pulling a rail car, but .... his truck does ride the rails.....:-D
wreckerman893
Possum Connoisseur
15,629
2,051
When I was in Korea I actually got to see the switcher mentioned above in action.
They had rail wheels adapted to the Rockwells on it and it was pulling a string of flat cars loaded with new M1A2 tanks.
I got pictures but not in digit form.
