brianrbull
- 9
- 18
- Casnovia Michigan
Ok so I come home on leave to play with my new toys....one of which is a M816 from Indiana decent truck but in need of a little love, Cables birds nested, no heater, somone turned the engine down so it hits the governer at 2000 RPM...nothing too serious but the hydraulics dont hold the boom creeps down fairly fast . I thought it might be air in the system but the hydraulic tank is full and I have run it up and down 50 or so times thinking that might fix it. I am now thinking that it must be a stuck check valve allowing the boom weight to push the oil back into the tank. I can see no leaks at any hoses,valves and the cylinder packings are dry . am I correct in assuming that there is a check valve of some sort? and if so can anyone tell me where it is located? Thanks
