wrecker seals
acetomatoco
Just take em to your local hydraulics guy as they are all std stuff on the M543A2 and M816.... some of the early Austin Western parts are harder to get.
devilman96
17
Boca Raton, FL
If anyone has an actual ID tag on their unit that you can pull number from I can prolly hunt them down... NSN / PN would be helpful also...
devilman96
17
Boca Raton, FL
will the spin motor be tagged its self. or do you need the tag from the wrecker bed
It HAS TO BE the tag on the motor... Motor seals come as kits (usually) and the only way of chasing them is with these tags, anything else on the motor is 90% of the time a casting number which could fit several diffrent motors of diffrent flavors... Every now and again you get lucky on some of the older stuff and the spec numbers are hand stamped into the casting but its rare...
Gamagoat1
Kiowa, Colorado
Here is the poop on my hyd. motors on the M816.
The winch motor:
Garwood 6385 (black tag)
P2048341
10876150
4-71
S-7488
The crane rotor:
Garwood 232 (red tag)
P204834D
10876151
3-71
S-8388
