jlt1987
- 7
- 3
- Wappingers Falls NY
Want to know thread and bolt size for front shackle
THREAD CLASS | 2A | |
THREAD DIRECTION | RIGHT-HAND | |
THREAD LENGTH | 1 INCHES MINIMUM AND 1 3/4 INCHES MAXIMUM | |
FASTENER LENGTH | 5 1/2 INCHES NOMINAL | |
HEAD STYLE | HEXAGON | |
HEAD HEIGHT | 0 189/500 INCHES MINIMUM AND 403/1000 INCHES MAXIMUM | |
WIDTH BETWEEN FLATS | 0 461/500 INCHES MINIMUM AND 937/1000 INCHES MAXIMUM | |
SHANK UNTHREADED HOLE DIAMETER | 0 7/50 INCHES NOMINAL FIRST HOLE | |
NOMINAL THREAD DIAMETER | 0 5/8 INCHES | |
THREAD QUANTITY PER INCH | 18 | |
DISTANCE FROM HEAD LARGEST BEARING SURFACE TO SHANK HOLE CENTER | 5 1/25 INCHES NOMINAL FIRST HOLE | |
COLOR | BLACK OVERALL | |
MATERIAL | STEEL OVERALL | |
MATERIAL DOCUMENT AND CLASSIFICAT | SAE J429 GR 8 ASSN STD ALL MATERIAL RESPONSES OVERALL | |
PROPRIETARY CHARACTERISTICS | PACS | |
SURFACE TREATMENT | CADMIUM OVERALL AND CHROMATE OVERALL | |
SURFACE TREATMENT DOCUMENT AND CLASSIFICATION | QQ-P-416 TY 2 CL 2 FED SPEC SINGLE TREATMENT RESPONSE OVERALL | |
THREAD SERIES DESIGNATOR | UNF |
Thank you. Who sells the parts manual .For the bolt.
THREAD CLASS 2A THREAD DIRECTION RIGHT-HAND THREAD LENGTH 1 INCHES MINIMUM AND 1 3/4 INCHES MAXIMUM FASTENER LENGTH 5 1/2 INCHES NOMINAL HEAD STYLE HEXAGON HEAD HEIGHT 0 189/500 INCHES MINIMUM AND 403/1000 INCHES MAXIMUM WIDTH BETWEEN FLATS 0 461/500 INCHES MINIMUM AND 937/1000 INCHES MAXIMUM SHANK UNTHREADED HOLE DIAMETER 0 7/50 INCHES NOMINAL FIRST HOLE NOMINAL THREAD DIAMETER 0 5/8 INCHES THREAD QUANTITY PER INCH 18 DISTANCE FROM HEAD LARGEST BEARING SURFACE TO SHANK HOLE CENTER 5 1/25 INCHES NOMINAL FIRST HOLE COLOR BLACK OVERALL MATERIAL STEEL OVERALL MATERIAL DOCUMENT AND CLASSIFICAT SAE J429 GR 8 ASSN STD ALL MATERIAL RESPONSES OVERALL PROPRIETARY CHARACTERISTICS PACS SURFACE TREATMENT CADMIUM OVERALL AND CHROMATE OVERALL SURFACE TREATMENT DOCUMENT AND CLASSIFICATION QQ-P-416 TY 2 CL 2 FED SPEC SINGLE TREATMENT RESPONSE OVERALL THREAD SERIES DESIGNATOR UNF
Will do. Thanks. CharlieYou really should download the TMs that are here for free and study them, then you would know what the correct name of each part is and much more importantly the part number, then you just plug the part number into your favorite search engine and take you pick from the available vendors that have that part.
Reading the -10 operators manual is also a VERY good idea as these trucks operate differently than any civy vehicle and that will save you money by not making the mistakes that most new owner commonly make.
