Lance Corporal
- 0
- 0
She's a no go. I got,er in 95 and it was previously used as a village street repair outfit. It's all still original and has collector plates. When I first got it I had to drive it home 5 miles --but- it wouldn't go in high rage/range. It was a slow trip. After a while it would only go after starting until it was put in neutral, but then it wouldn't go back in gear until after it sat for a while. Then it got to a point of not going at all. I changed the gov rings because being stupid and not knowing things I broke one putting it back together. I was trying to clean things up a bit thinking that it was clogs in the shift valve etc. It seems there's a rubber pad missing in the hi/lo range selector atop the second drive unit. When first aquired it would lockup in high range as if in two gears at the same time. The lockup was the first problem, now it dosn't go at all. I'm going to check pump pressure when proper gear arrives to do so. It seems to have happened after changing the trans oil. There was cows snot at the bottom of the pan so it looks like the oil hasn't been chaned since 52. This is a 52 GMC M35. Ed 1819671
