XM 211 Master Cylinder
cmaas
Anacortes, WA
What a lot of great information on this forum! Now I have a question and haven't found the answer in search.
I've got an XM211 that is used as a fire truck. The master cylinder needs replacing as the pits in the bore are too deep to hone out. I got a new one from Memphis and it looks basically the same. The main difference is that it won't accept the threaded fill pipe that came off the old one. In a pinch I can fabricate up some way to get that fill pipe on there but my questions are do I need that pipe and is there any other reason this master cylinder might not fit?
I've read that there are similar looking master cylinders but that have a check valve. This new one doesn't look to have any parts the old one didn't have.
Any opinions? Thanks.
cmaas
Anacortes, WA
Wait, I was wrong. The new one does have a check valve. The weird thing is so did the old one (I didn't realize what the little dome shaped thing was) but I think it was reversed so it was on the piston side and didn't do anything. Anyway it sounds like I don't want a check valve in there. So that still leaves me with the fill pipe question.
USMC 00-08
165
Skiatook, OK
You don't want the check valve in there if you still have the original airpak installed.
I have heard that the pipe gives added capacity since you have 12 wheel cylinders on the truck. The cap has a vent on the top and that cap can't be used without the pipe. If the pipe doesn't fit, I would send the master cylinder back and get the one we have listed in our parts list here.
http://www.steelsoldiers.com/showthread.php?137722-G749-Parts-List
It worked great for me. The black plastic cap on there was just to keep anything out. I used the cap that is original to the truck when I installed the master cylinder
Here is what the original airpak looks like.
cmaas
Anacortes, WA
Thanks for that. The Napa one sounds like the way to go. I just talked to them and they can order me one for $220. So a little pricey but oh well.
That air pack looks just like mine as near as I can tell. Minus the dirt and rust.
