AMGeneral
- 115
- 63
- Connelly Springs, NC
Ok,seeing as I have very little "road time" behind the wheel of a GMC deuce,I have a question to pose.......
My GMC seems to be "sluggish" when starting out, almost like the driveline is binding up or under load, It's more noticeable in high range vs low.
I know most automatics will "creep" forward in drive,just with the engine idling,but the GMC will stand still in High and barely move in low at idle,warm or cold.
I have checked the following.....
Brakes for dragging,all of them are free,even the parking brake,none hotter than the rest after driving.
T-case front axle engagement linkage,everything working as it should.
The trans output shaft turns freely with the t-case disengaged,no problems there.
Winch PTO is definetly disengaged.
Tires are basically the same diameter all around(worn out).
I HAVE NOT removed the front driveshaft yet and driven it without it.
Anything I am missing?
