Wow, it's almost 3 months since I started this topic. A couple months ago I found that what appeared to be the correct shift shaft had some linkage to a lever in the cab. I studied it and experimented with shifting it while turning sharp and moving forward and backward. The driveline still seemed to bind no matter what way I "shifted" it. Obviously, this truck is a back-back burner project. And I think I've exhausted all the time on it that I want to this year. And maybe next... lol
Sorry USMC 00-08, I don't do the pic thing very much. A short time after you asked I attempted a reply (that the computer ate) and I walked away till now. The truck has faded ODish paint, a cracked driver windshield, no wipers, and a winch that needs a cable replaced. The bed dumps thanks to what appears to be a hoist from a "2-ton" grain truck (probably where the engine/trans came from, too). Also from a grain truck is a vacuum booster. This fall I managed to put a different master cylinder on, bleed the brakes, and replace both PTO cables. I temporarily had brakes, until a wheel cylinder bled them dry for me. As I mentioned, I'm outta gumption for now.
