XM757 progress
cranetruck
75
Meadows of Dan, Virginia
Been working on the coolant heater for a while now, image shows installation with circulation pump. Fuel line and wiring still has to be completed.
Two separate coolant circuits can be selected, one to heat the driver's side fuel tank and one to heat the engine....
WillWagner
2,574
Monrovia, Ca.
Looks good Bjorn. Have you been able to put any road miles on it yet?
Desert Deuce
17
Chino Valley, AZ
Bjorn, Very nice, having all accessories opperating is very cool. Did your XM757 have this or are you adding it. And, are you installing per TM or doing some engineering yourself. That machine is a beauty.
cranetruck
75
The coolant heater and circulation pump are located per TM, there were dimples in the floor for drilling the holes to mount the heater, actually, so it's in the corrct place.
I do add a few features, but nothing drastic. :)
Will, so far I have only driven it around the yard, but with the auto trans and pwr steering it's very easy to move around.
The dash area is being worked on as we speak....
