Yesterday started fine. Now slow start
redrocket78
Gloucester VA
So yesterday I turned the AC switch on and the truck fires right up. Today the truck turns over for almost 20 seconds and then starts right up. ( 71 M35A2 multi fuel) Did some crawling around the truck and it seems once the truck is shut off you can hear the fuel pouring back into the tank. I checked all the lines and fittings and there is no moisture or loose fittings I can find in the fuel system. If I turn the AC switch to the on position and give the fuel pump a few seconds then the truck fires right up.
So the question is. Is there a check valve in the tank that could be malfunctioning or is there something else I'm not thinking of. I am a total newb when it comes to MV's but very mechanically inclined. Perhaps the fuel pump seal or something.
Thanks in advance.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
You're new so I'll do you a favor and move this thread to the proper location (The Deuce forum). If you put it in the right spot you'll get much better exposure and better responses to your question.
Tow4
674
Orlando, FL
Welcome from Florida.
Let the electric pump run for a few seconds before you crank it. If it sits for a few weeks you can push the accelerator down a little while you crank to make it start easier. Let off the accelerator when it starts so you don't rev the engine before the oil pressure comes up.
It's all in the TM.
swbradley1
Modertator
1,945
Dayton, OH
One of my trucks will start up immediately whether it sits for ten minutes or ten months the other I have to push the pedal down and crank for as much as 15 seconds.
197thhhc
15
Williamsburg, OHIO
I would replace your filters if you haven't yet. You need to anyway. You also may want to check the hose on the intank pump. They can crack and leak or loosen up. This is sometimes a warning the hose is about to tear loose. and that will leave you stranded somewhere.
