scottmandu
- 35
- 28
- Texas
Here's the A/C install I did on a M1078A1 that is going up north to a customer. Install went clean and works better than the A/C in my car.
I've got a web folder of where the major components go and have put images below.
http://advancedautomotion.com/LMTV_AC_INSTALL/index.php
I've made an improvement to the condenser over the horribly inefficient Red Dot unit. It still needs larger condenser though as there is still vapor in the liquid line, but it works ****ed good as is. The only other modification that is needed is to brace the low pressure tube coming off the compressor.
