This past weekend I tried resurrecting my MEP-003 I got from GL. We were able to free up the injector pump last week, so we decided to put it back on and crank up the genset. Keep in mind I have never seen or heard this generator run. From the injector shims I acquired through 2 different sources I couldn't make the .012" total shim thickness that was on the set before, but I could make .013", so we went with that. We timed the engine and put the IP back on. So far, so good.
Then we pulled the spring from the injector pump valve to prime the IP. Turned the fuel pumps on, loosened the injector lines at the injectors and slowly spun the motor over by hand watching for fuel coming out of the injector lines. All 4 primed, excellent. Reinstalled the spring in the injector pump valve and torqued to spec. Cool.
We then tried to crank the engine over and the starter wasn't seeming to spin the motor fast enough. Every once in a while we'd get a thunk of a cylinder firing, and once got the engine to hit over 6 or 7 times in a row, but no running. The starter was probably running less than 100 RPMs, so I think that may have been my issue keeping me from starting it. Grrr.
So, we decided to call it a day until I can get the starter rebuilt. Threw the breaker bar back on the blower bolt to spin the motor over for some reason, and now the motor doesn't seem to want to spin past a certain point. Crud, sounds like it's seized. For kicks, I bumped the motor with the starter one more time and it looks like it still spins the motor. I think the cylinders got washed and lost lubrication.
So, we dumped some Marvel Mystery Oil down the glow plug holes and tried to work the engine back and forth by hand. It seems to be loosening back up. We can now spin it full rotation again, though with more effort than was previously required to spin the motor by hand.
Any tips, tricks, or suggestions to aid in my quest of bringing this genset to life? I will hopefully send the starter in to be rebuilt sometime this week.
