Zenith Carb Swap
Barrman
1,774
Giddings, Texas
I thought you just got your Zenith figured out?
Both of my Gassers have the stock Holley on them still.
Several members have also swapped in civy versions of the Gold Comet engine parts to get better performance.
jmoylan69
crescent valley, Nevada
Barrman, i did and do. but what i got is it seems like the fuel pump is over supplying the carb. I rebuilt the fuel pump with a new kit, and checked the float height and if the float was sinking and sticking. im good there! the pump is the original mechanical pump with new check valves and seals. the zenith manual for 28ada10 calls for a float level of 1.5 inches.
you think im missing something perhaps?
and HNDRSONJ, thanks for the info i'll check those out too!!!
Barrman
1,774
Giddings, Texas
My rebuilt Holley to spec bubbled over after idling at least 10 minutes. I kept adjusting the float down just a hair at a time until it would idle all day long without getting the burbles. Still had great WOT application at any rpm. I have no clue what I finally ended up at, just that it works.
I know that really doesn't help you, but with 60 years of chemical changes to the fuel. What worked in 1951 might not be all that great today. Besides, it isn't like you are going to go from 4.9 mpg all the way up to 5.3 mpg or something drastic like that. Just make it so you like the way it runs and leave it alone.
jmoylan69
OK barrman, believe it or not that does help me out. I was thinking these things had to be adjusted to the gnats @$$. my thinking was along the same lines. good to know and thanks again.
joe
jmoylan69
hey jason what are those running these days? can i pick em up cheap or are they 400 dollar carbs?
i've always had this thing about spending a ton of money on carbs. and i personally have never seen an 885 FFG holley
JasonS
144
Eastern SD
and that setup you have looks good to me. but I know the full value of oil bath filters and would prefer to keep mine. they really pull the dirt out
You will be fine with a good paper element. You could probably even use the multifuel air filter.
JasonS
144
Eastern SD
I spent ~$50 to $70 each off of ebay. They are significantly improved from the simple holley and zenith. Specifically, they have better (economaster) boosters, two stage power valve, and reverse idle. Much better driveability.
