Can that green label And get an S3 EESS with matching TSUI have a green label KDS box that just started to fail (wait light blinks one time quickly and glow plugs do not heat upon turning the "start switch" to run)…. I've checked the glow plugs and installed the grounding harness, and have had no luck with the box (based on my research I'm suspecting its dead).
With that said, I'm looking to replace it with one of the newer smart boxes (S3)… my question - is there any difference between KDS and Nartron?... is there a preferred brand over the other? the KDS box is part number 2700CR... the Nartron is MFR - 32498.... If these boxes are backwards compatible with the TSU's, would TSU (part # 1310055; NSN 2920-01-175-7214) be compatible?.... I apologize if this has been answered, but can't seem to find any opinions on this...
I thought the KDS (2700 CR) and the Nartron (3249Can that green label And get an S3 EESS with matching TSU
Model of truck means nothing…Ok. Great thread. Newb here. Haha
I get that a specific box requires a specific TSU but....does a specific box and TSU have to go to a specific hmmwv platform. I just fried my KDS box (black box fried when reattached negative terminal) in my M1097A2 and looking for a replacement. In my searches, I can find a new box with matching TCS but unsure if it is compatible with my platform.
S3 EESS or nothing, it’s either a Nartron or KDS, the TSU is regardless of mfg…Nartron or KdsGreat. So to be clear, I can purchase any matching box and tcs and install.
Is yellow for sale?Here's some photo's...
First is an old LAU.....not used anymore.
PN 12379864
# 2..KDS green label...CR-2699.....burnt and corroded.
This old type can use any temp sensor.
View attachment 666796View attachment 666797.
This one...KDS yellow label 12469158-1
Can use KDS or Nartron temp sensor 12469158-2
View attachment 666798View attachment 666799
Hi, I have that same yellow smart box and not knowing how sensitive these things were. I was adding a light at 12 V light to the battery and I accidentally grounded positive on the battery to the frame and now I’m not getting any power to the glow plugs, shorted something out. Do you repair these smart boxes? Or do you have one to sell?Upon purchasing my M1038A1, I was plagued with absolutely torched glow plugs. Not knowing any differently, I purchase another set, installed and immediately smoked them too after two successful starts. Getting a little smarter, and doing a lot of research, I dug into my issue (GPs staying on all the time and never shutting down). I verified my suspicion by hooking up a 24v light to one of the GP connectors, you guessed it, the light never went out, meaning that once cycling from off to run it was on like donkey kong except that means catastrophic failure of the GPs.
All this to say, I was able to repair the EESS, and now have a fully functioning starting system.
Not sure if this is the right place for this but I would be happy to help others with addressing this same issue.
If anyone out there has this specific box:
I would be open to having it shipped to me, and repaired and returned.
We can work out shipping and payment pretty easily.
PM me with interest.
Adding the light is a bright idea. Real question is DO you really want an old computer going wonkie controlling your glow plugs and ability to start and understand the goings on?Hi, I have that same yellow smart box and not knowing how sensitive these things were. I was adding a light at 12 V light to the battery and I accidentally grounded positive on the battery to the frame and now I’m not getting any power to the glow plugs, shorted something out. Do you repair these smart boxes? Or do you have one to sell?
