- 591
- 683
- 93
- Okinawa, Japan
Thank you.awesome work, keep it up. I'm curious to see how the center mount 6.5 works out. i have a hummer takeout and a civ 6.5, one of which is going into my new to me 1028.
The other day I came across turbos mounted somewhat like you plan to do. I believe it was on vans. Might be interesting for you to read up on that. Google it. Must've been on The Truck Stop or Diesel Place.Thank you.
I've decided to relocate the turbo in between the frame behind the cab. I will use a NA 6.2 driver's side exhaust manifold and run pipe from each side back to the turbo.
I have a doubler kit on the way. I need to get the transfer case mounted and the angles right for the drive shafts before I do anything else.
They will be few and far between until I return from Okinawa in June 2025.Subscribed for future updates!
