AWOLs 1997 M1097A2 Build
Awol
335
MA
So I have the truck running off a diesel can right now, with a mixture of diesel and atf in it. Also poured some atf into the fuel filter housing, hopefully to free up anything that's sticky in the IP.
While doing that, I power washed the fuel tank. It's not perfect, but it's clean. It was covered in GA mud/clay. Also discovered the fuel sock fell off the sending unit. A new one is in order anyway, as the original was almost 100% plugged with junk.
19,245
View attachment 919331View attachment 919332View attachment 919333
Looks like you got it pretty clean!
Fuel sock was sloshing around in the bottom of the tank?
Awol
335
MA
Yeah, just floating around. lol
When I drained the tank it probably had 10 gallons of water in it. It definitely wasn't gonna run without a draining and thorough cleaning.
Awol
335
MA
Good Deal.
Glad you got it drained and cleaned out!
Definitely before you tried to start it...
Yeah, one look at that tank and I knew I needed to run the truck off a fuel can until I get the tank cleaned out. I ordered a new sock, and drain plug. Both were smoked. I was surprised the drain plug was holding anything.
While the tank is down, it's getting all new rubber lines. The ones on it now look original to the truck. Brittle as hell.
Still have the stumble and die when letting off the throttle, but I'm hoping that atf works its way in the IP and frees some stuff up. I really don't want to pull the IP.
Awol
335
MA
Forgot to post these pics. This is what the IP looked like inside when I first got it. Absolutely disgusting. The fuel looked like mud when I pumped it out.
Also, I think I figured out my off idle stumble. I turned the idle up 1 full turn of the screw, and now it doesn't die when returning to idle.
19,245
CapePrep
194
MA
View attachment 919451View attachment 919452View attachment 919453
Nasty. When I mentioned earlier about the oil change due to water in fuel tank, this is what I was referring to! That transfer pump sucked water out of tank and into your IP. Which than gets into your crankcase. Glad you're getting it all cleaned up and running properly.
Awol
335
MA
Yup, it's coming along nicely.
Also, traced those lines from that cannister in the engine bay. It looks to be a catch can of some sort. One line runs into the driver valve cover, the other goes to the block right above the oil filter (small line with crimp fitting)
Mogman
8,505
Papalote, TX
I am curious how the water gets from the IP into the crankcase?
Just1More
Bremerton, WA
Looks good! I would open up the catch can looking thing to see what's what. Reminds me of the old school secondary oil filters that use a roll of toilet paper. Maybe there's a part number on it.
Awol
335
MA
I plan on digging into it later today. I think I saw a brand name and part number on it. I'll report back with what I find.
Awol
335
MA
Took some pics of the catch can. It has a drain valve on it, but it's empty. I haven't attempted to take it apart yet.
Just1More
Bremerton, WA
Interesting. I'll keep following the thread in case you open it up. I've never seen one that's supposed to be mounted on its side either. It still might be a bypass oil filter.
Awol
335
MA
What were these two vent lines off the fuel tank supposed to run to? They were disconnected and bypassed when I got the truck. I haven't reinstalled them yet since putting the tank in.
