Continental's CMD-350; a 350HP multifuel engine
JasonS
126
Eastern SD
Continental developed a 350HP engine based on the 478 cubic inch "multifuel" engine.
Some interesting features other than the power output:
  1. Variable compression ratio: a high of 17:1 and a low of 10:1
  2. The BSFC was 0.380 lb/ hp*hr which is actually better than the LDS engine
  3. Still using the American Bosch PSB injection pump
  4. Aftercooler built into the intake
  5. Aluminum heads, oil filter housing, and rocker covers
G744
3,547
Hidden Valley, Az
I'm so glad "they" know the bottom end can handle those ponies...
I don't, having seen hundreds of LDS & LDT engines at Yermo with the center web blown out.
The old MSG there called them light bulb motors, 'cause you never know when they would blow out...
rustystud
2,492
Woodinville, Washington
Thanks Jason. That is some cool information !
swbradley1
Modertator
1,590
Dayton, OH
After seeing your response it makes me wonder if the web blew our from the crank breaking in two or the web broke and took out the crank. I had never wondered that until now. I had just assumed the crank broke.
Either way, it was something to see and hear when I started the truck up.
gringeltaube
Staff Member
2,304
Montevideo/Uruguay
I would love to see a diagram of the design.
This is just one of multiple solutions for VCR....
Not sure though, which way they went at Continental. The brochure talks about hydraulically operated pistons "whose position relative to the crank pin ...." so I guess what they used are these variable-length con rods, with their eccentric piston pins. The pin itself does not vary its distance to the piston; only to the crank pin.
rustystud
2,492
View attachment 884334 View attachment 884336 View attachment 884337
The question that remains is how did they activate the pistons ? Was there two oil holes drilled into the crank per piston ? One hole providing oil for the bearings and then the other providing the oil needed to move the piston in the piston ? I wonder.
HDN
4,804
Finger Lakes Region, NY
That's all I can figure, like a hydrauluc spool on an excavator, except it's spinning a lot faster o_O
Gypsyman
740
Quincy, FL
My brain went straight to this question too Rusty.
gringeltaube
Staff Member
2,304
Montevideo/Uruguay
It actually works by varying the oil pressure in the crank.
Here's some reading to it and two (hydraulic) schematics, taken directly from Toyota's patent:
(still need to find the list of components, in order to better understand all those numbers...)
"Toyota idea takes a conventional connecting rod and mounts the top of it to a pair of hydraulically controlled pistons. By adjusting the oil pressure, a switching pin and check valve would be able to alter which of these pistons compresses. By doing so, the length of the connecting rod changes between two lengths – a high-compression and low-compression setting.
Generally when the switching pin (*) receives a certain amount of oil pressure, the connecting rod would be in its longer length, and the engine would operate at the high compression ratio. Alternatively when the oil pressure falls below a predetermined level, the connecting rod would be in its shorter length and be in the lower compression ratio. However, the patent is clear that the company could configure the change in oil pressure have the opposite effect, too."
(*) That would be #81, clearly
4,647
Interesting. I thought perhaps it worked like the old International/McCormic tractors that started on gas and swapped over to diesel. They simply used an extra valve that allowed the gas side of things to work by increasing the combustion chamber volume (and hid the spark plug away from the cylinder). Then switched closed to allow the cylinder to achieve the higher compression needed of the diesel operation.
The varied oil pressure from the crank would allow it to operate more dynamically though. But I bet this setup lends to interesting failures.
gringeltaube
Staff Member
2,304
Montevideo/Uruguay
We still don't know what exactly Continental did to achieve VCR. Clearly, this engine never went into mass-production. Guessing high cost was a big factor, as well as many more parts to fail...
rustystud
2,492
I was thinking the same thing about failures too. Like what happens when a bearing starts to get loose due to wear and oil pressure drops on that rod only. Lets say oil pressure drops on that rod and that piston change it's compression and the others don't. Now we have a severe compression imbalance.
silverstate55
Unemployable
855
UT
My neighbor has a McCormick-Deering Farmall tractor that is set up that way. It’s pretty cool.
