Cooling system filter set up
CES 3245th
Boston Ma
I realize that this request has probably been beaten to death.... BUT I have looked through a bunch of the posts in reference to this and their looks like several options for connecting these hoses. So if I can ask, I'm looking for the best location and for the best results for the tie-in of these two hoses coming off the filter mount bracket. Pictures would be great as well as your opinions. This application is for M923A1 NHC-250
Thank you in advance
Jbulach
2,110
Sunman Indiana
Unless your cooling system is already clean, If you can, wait till the heat of the summer to flush your system and install your filter. I just did my A2, and what a bear trying to get all that sludge out in cold temperatures. I went through ever bit of 1000 gallons of water, and a half dozen fill, run up to operating temperatures, drain, cool down, and repeat. I'm still not happy with how much craps in there, will see what else the filter cleans up?
CES 3245th
Boston Ma
You are definitely correct on waiting it is way too cold out to be doing that. Thank you for that info by chance do you have any pictures of the way you set it up.
