You need 1/4"-20 Heavy Duty Rivet Nuts from McMaster Carr. http://www.mcmaster.com/#catalog/121/3306/=zgujfw
Don't buy the aluminum - get the Zinc Chromate plated steel ones 95105A143 for $9.08 for a pack of 25. You will also need a sharp 25/64 drill and a tool to install the rivet nut. McMaster sells the tool for $30 http://www.mcmaster.com/#catalog/121/3309/=zgun2q but a lot of guys make their own. Basically you position the antennae mount where you want it, mark the holes with a Sharpie, then drill the 25/64 holes. The rivet nuts are sort of giant pop rivets but threaded on the inside. When they are crimped into the drilled hole, they provide a 14"-20 threaded socket to run the bolts into. Kinda neat, really.
Hope this helps.
Hope this helps.
Rivnut is what you need.
