How do you move your generator(s)?
DieselAddict
1,890
Efland, NC
I haven't moved mine in years but the last time I did I used my 4310 John Deere. It is equipped with a 420 loader that I upgraded to 430 specs by installing 2" generic cylinders. I used clamp on forks and attached to the lift rings on the 803. I strapped the end closest to the tractor behind the loader pins. I had 1200 lbs of ballast on the 3pt end of the tractor and the 803 was all it wanted to lift a few inches off the ground.
I’ve been on the lookout for a 420 or 430 loader for my old JD reactor.
spotrep
Texas
I don't own much in the way of material handling equipment and have typically relied on my tilt-deck trailer and a small dolly with floor jacks to move stuff around. Recently I built a pair of towable dollys to improve my ability to shuffle generators.
It got me curious how all of you move a half ton or more of surplus around. :giggle:
I love this idea! My garden tractor doesn’t have a 3 point but I can put a Jack on it. What’s you use for the axle? I tried to send you a message but I don’t think I have enough posts yet
Digger556
535
Denver CO
1 inch cold rolled steel, turned down to 3/4" on the ends.
Jayhawk#44
132
33
Arizona
MEP-803A, rented a forklift ($200) to get it off the trailer and in the garage. floor jacks to lift it, jack stands to hold it up.
Built a 4X4 frame between the rails and bolted 2 large fixed casters at the very center balance point. Then bolted 2 1/2 inch ish smaller swivel casters at the 4 corners. I can easily move it in, out, and around my garage with ease by myself. Jumps all gaps in the concrete with ease by just hitting 1 wheel at a time at an angle.
Got the idea off a post on here somewhere. Its buried right now, I'll post up some pics sometime when I unbury it.
Later,
Matt L.
rickf
1,321
Pemberton, N.J.
Just be aware that bucket lip pallet forks WILL bend your bucket!! And once bent it will never grade properly again. The best bucket forks are like the ones I had on one of my backhoes that actually attached to hooks welded on top of the bucket in four spots across the top and that swung on those and the backs of the forks butted against the front of the cutting edge of the bucket. This way the weight was carried by the top of the bucket where the reinforced mounts for the cylinders are. No bent bottom bucket surface. You can modify old forklift forks to work this way if you have a good heavy duty welder.
98G
Former SSG
4,066
They make forks with a frame that take the place of the bucket. They're not a lot more expensive than those bucket ruiners.
I have no idea how I ever lived without them.
Sazabizc
19
Wv
My pallet fork is on a frame . No clamp on bucket forks here. And I love my quick disconnect attachments 5 minutes is all it take to switch attachments if they are side buy side .
I also recently drilled a hole in one of the forks so I can tread on a Reese hitch ball. That way if I’m trying to hang a rope or chain off the fork it can’t side off .
Sure bites rolling heavy drums full of diesel into the bucket and having to manually move them into place .
Leonardo82nd
70
Edinburg Texas
Backhoe/ skid steer OR when in a bind . Call a wrecker (flat bed ) guy charged me $75 To transfer it to the bed of truck . When offloading , I throw some pipe under and push it off the bed of the truck down a harbor freight ramp. slides fast as hell, but Never failed. For around the shop they sit on pipe to slide around as needed.
