Lock for the battery switch
JonM934
221
Herriman UTAH
So I wanted to lock my truck that would prevent it from disappearing one night. I know I could lock the steering column but I saw that the battery switch was also able to accept a lock. So I played around and found that most locks had a shackle that was too large to fit through the holes. I found one at Home Depot that could fit through the holes and also had a shackle that was wide enough to fit over the switch.
This lock has a 5mm shackle and it is a little loose in the holes for the battery switch. I think a 6mm would also fit but I could not find a lock with that size shackle. I did try a 7mm shackle and it is too large to fit through the holes.
I understand that it would be easy to break the lock but it least it will stop most people.
I can sleep better now.
Jon
JonM934
221
Herriman UTAH
I changed this message to say battery switch instead of battle switch even though in the manual I thought it referred to the switch as battle. And here is a photo:
The lock is black and the switch is black so it is hard to see when the lock is turned to the side. Below, I turned the lock so you can see it but I try to keep it turned to the side so it is hard to notice.
