Barrman
- 1,649
- 113
- Giddings, Texas
I am putting a HMMWV can 6.2 in my M715. It had the long injectors which resulted in the #6 and #8 lines hitting my heater housing when we test fitted the engine. Not to worry I thought because Warthog has a 1988 CUCVII/contract military truck with a 6.2 and short injectors in my pasture. I put the engines next to each other, removed the intakes, removed the lines, swapped each injector out and then tried to keep the short injector lines with the short injectors and the long lines with the long injectors.
Nothing matches up. Since I had the lines still bolted as a side set, I figured it must be the different valve covers. Valve covers were swapped engine to engine. Which will actually be a good thing since the '88 engine has the valve cover mounted vent system compared to the CUCV snake nest vent system for the engine. Nope, that didn't help any either.
Valve covers back off and the lines just don't match up. When paired with the injectors they used to be bolted to. Nothing came apart hard either.
However, I can put the long lines with the short injectors and just a little push makes them fit. I haven't tried the short lines with the long injectors yet. The only thing different between the engines is the fittings on the IP. The Can engine has shorter fittings at the IP. But, since the trouble has been distance between the valve cover and injector, I don't think that is it.
Has anybody else ever run ito this? I will make them work, but keep thinking I missed something.
Thanks.
Thanks.
