M916-M920 Tech & Tips
Jeep Nasty
242
NH
I was wondering if you could help with with the front drums on my m916. I have the front drum/hub assembly removed to take to the machine shop to machine off the required material to fit my HEMTT wHeels with 16.00r20 tires. Is there a process for separating the hub from the drum to make it more manageable for the the machine shop or does the hub/drum assembly stay together the whole time. The TM did not go past this point?
86m1028
Murphy TEXAS
When I did my m916, I did NOT separate them.
Machine shop had no problems turning them as an assembly.
I did take them a wheel to measure for clearance.
To answer your question, I believe the wheel studs are pressed in & hold them together. It's been awhile since I did them.
The 16.00's are nice they look like they belong on the truck stock.
Jeep Nasty
242
NH
Thanks, I went them same route keeping them together
kennys@wi.rr.com
23
Waukesha, WI
My original post was on 1/6/2011. Exactly 8 years later I was on my way to pickup an M920 in NC. Dreams do come true.
I would like to learn more about the M920 before I seriously toss my hat in the ring to buy one. Is there anyone in the SE WI area that has one? Or within 100 miles or so of the Milwaukee area? I'd just like to be able to crawl around one and get a ride in one just to help me decide if it's what I really want to do. Cool factor is there for sure, now comes workability and driveability for me.
rd3war
PA
How hard is the steering on a M916? I have a 1980 M916 with 16's that seems like I have to put a lot of effort into turning the wheel. For example making a right or left turn at an intersection requires some muscle. The only other vehicle I have to compare it to is my M1078 which you can turn with one finger on the wheel, but the M916 is a whole body effort! The power steering fluid level seems ok, there is fluid in the reservoir (maybe a couple oz. low), I need to check again when hot.
simp5782
Feo, Fuerte y Formal
9,313
Mason, TN
I have a few take off power steering units.
How is your freeplay in your steering assist cylinder? Sometimes they make it stiff to turn.
rd3war
PA
How do I check freeplay in the cylinder? The grease fittings around it seem to be well lubed. The steering box is solid, no slop there.
simp5782
9,313
Mason, TN
Undo the tie rod and check movement sliding it in and out with the lines at the cylinder cracked open. old hoses connecting to the cylinder could be deteriorating inside causing a restriction or your steering pump is just getting weak
simp5782
9,313
Mason, TN
You can also cap those cylinder lines off and drive it and see how it does. I have mine capped off in my 920 and I run 445 65 22.5 steers and have a 16in steering wheel and mine turns fine
