M939/LMTV/FMTV Air dryer replacements/upgrades
Iron Moose 5 Ton
Grantville PA
Copy. Thanks so any dryer will work then. I was curious because the shop that replaced my dryer used a WABCO 1200 series and I was pretty sure it was only a 3 line dryer as well. The fire department wants to go with this dryer. Will this work without any problems? Thank you for all the help and assistance. Very much appreciated. https://www.ebay.com/p/1360078440
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
There won't be any issues. Just drill your correct mounting holes on the bracket and hook it up.
Iron Moose 5 Ton
Grantville PA
Copy that. Thank you very much for the help and assistance. Will I need any adapters that you know of or should it be a direct fit? If I do need adapters I would stick with brass adapters?
simp5782
9,285
Mason, TN
I prefer steel. Brass just snaps too easy especially with any vibrations. air dryers do vibrate. You may need a bushing or two to reduce or increase. But. You may need all new fittings cause the Wabco unit uses Boss type metric threads. The AD9 will use pipe. Unless they used adapters
Iron Moose 5 Ton
Grantville PA
Okay. Thanks. I will stick with steel/iron fittings then. I ordered the Haldex Dryer today. Should be here in the next few days. Thank you again for all the help and assistance.
