M939/LMTV/FMTV Air dryer replacements/upgrades
simp5782
Feo, Fuerte y Formal
9,316
Mason, TN
I agree about price being important, but the 24v AD-9 is about $150, versus $185 for the turbo 2000. Unless you found them cheaper somewhere else, if so pm me the link.
I went with the turbo 2000 due to the mounting bracket. As well as the heater keeps the cartridge heated as well not just the purge valve
LCA078
Austin, TX
First, thanks for the write-up Simp- great info.
Second, I'm still learning about air brakes so how does a heater remove moisture from the air brake system? I thought to remove moisture from compressed air, you had to condense it out through cooling, not heating.
simp5782
9,316
Mason, TN
The heater is there for keep the purge valve from freezing since water forms and is dispensed thru it and can gather there
LCA078
Austin, TX
I forgot about the f-word. Not something I worry about too much down here.
Follow on question: Does the regular heater like I have operate continuously so I can verify it's operation on warm days by feeling it? Or is operation based on outside temp?
MyothersanM1
19K M1 Armor Crewman
410
68
Culver City, CA
Pardon the ignorance, the installation instructions for the Turbo 2000 says it requires a purge tank, but I read here it sounds like you do not need one. I have also read on the SKF website that this particular air dryer builds its own sufficient purge air without the aid of a tank.
Can anyone clarify this conflict in information? Thanks.
simp5782
9,316
Mason, TN
You do not need it. simply block the port off. I did this on the Wabco driers as well. There are Holset compliant and non holset compliant Turbo 2000 dryers as well the compatible has a yellow tag. The non compatible has a red tag.
MyothersanM1
410
68
Culver City, CA
Thanks for the clarification, Simp!
Looks like I am going to ditch my Pure Air.
Russ Knight
1,051
Perry, FL
Wes, just to verify, the SKF Brakemaster Turbo 2000 is a direct replacement, will bolt up in the stock location (in front of the first rear axle on the crossmember), and all tubing will connect. Purge tank port (3/8") must be plugged. And where is currently the best place to purchase one?
simp5782
9,316
Mason, TN
Yes russ they bolt to either the 4way or 3 bolt pattern. There are some on ebay as of late. You can use the 12v heater unit since it doesn't get used that often in your neck of the woods anyway. According to skf the heater is omni volt anyway
TEAMJENSEN
NJ
I want one of these, but haven't been able to find one! Anybody got a link/source to purchase one??
I found mine on fleabay. Search "skf brakemaster" it will pop up with a 24v unit. The seller is in oregon.
Sent from my SM-G973U using Tapatalk
SCM35A2
2,775
Florence, SC
Oh I have tried Ebay, that one seller who had tons of them sold out before I could get one. I was my fault, I forgot about them being such a good deal.
simp5782
9,316
Mason, TN
