- 297
- 379
- 63
- Geographical Center of Virginia
Excellent condition super clean MEP-004 15 KW Diesel Generator 60hz. This unit was rebuilt and has a 2007 rebuild Melton motor installed and is at 17 original hours. Load tested and needs nothing. Can easily be installed for use in a home, shop, or other uses. I offer single phase conversion and yes you will get the same full rated output in 120/240v conversion. Mounted on HMMWV Generator Trailer. Fresh fluids, filters, and misc new parts. It was surplused to a county and they rarely used it. EMP proof, extremely heavy duty, much more reliable than the newer series (MEP-804). These are rated at 15kw 24/7 use, only needing to stop every 500 hours for an oil change. You can easily get well over 10,000 hours of use before needing to rebuild. This is the most recently rebuilt Generator I've had. I have other MEP-005 30KW Generators available for sale. I've serviced and sold military generators for years.
$5500 with trailer OBO/TRADE
$4500 without trailer OBO/TRADE
Located in Cumberland VA 23040. Yes I can load it on your trailer or in the back of your truck.
May consider trades for skid steer attachments and other military equipment/vehicles.
15 kW, 50-60 Hz, Diesel Engine-Driven Generator. Characteristics: Description: 15 kW @ 0.8 power factor, 50/60 Hz, 120/208 V, 240/416 V Physical characteristics: Dimensions: 70″L X 36″ W X 55″ H Weight: 2450 lbs (1293 kg) Mobility: Fully housed. Mounted on skid base. Lifting and tie-down attachments provided. Fork lift provision. Engine: Diesel Horsepower: 45 @ 1800 RPM. Cylinders: 4 Cycle: 4 Operating speed: 50 Hz: 1500 RPM, 60 Hz: 1800 RPM. Fuel: Diesel Fuel Oil Electrical: Drip proof generator enclosure. Capable of parallel operation. Voltage Connection: 60 Hz: 120/208 V, 1 & 3 phase, 4 wire. 240/416 V, 3 phase, 4 Wire. 50/60 Hz: 120/208 V, 3 phase, 4 wire. 240/416 V, 3 phase, 4 wire Notes: Liquid cooled.
