multifuel injection pump change
junkyardog
wakefield new hampshire
any pointers on doing a injectin pump on a multi fuel. i have done them on a cummins and mack.i have got the timing prcedures from the tm guide.looks like it would be better with the fender off but time will tell i guess. i thought it was the fuel transfer pump but it is the seal in front of the pump where it bolts to the eng. was ther a procedure to change the fusl lines around so it just burn diesel. i have heard that without changing them over you are subject to the problem i have (fuel in oil).
