HDN
- 4,804
- 113
- Finger Lakes Region, NY
I'm trying to figure out if my oil pressure gauge is shot.
The last drive during cooldown the gauge was reading under what idle pressure should be. Prior to that the gauge was reading properly with the truck parked and driving. I thought the truck was idling lower than usual, which could've had something to do with it, so I finally fixed the tach to see if that was the cause.
I fixed the tach and was getting zero pressure on the gauge. I shut the truck down ASAP and started troubleshooting:
1) Disconnect lead 36 at sender to check gauge operation. Gauge should be at MINIMUM.
Guess what? The gauge was reading at MAXIMUM.
2) Remove gauge cluster, connect negative multimeter lead to good frame or body ground and turn on electrical switch to check voltage at lead 27 at gauge with positive multimeter lead.
I get voltage at the gauge.
Did my oil pressure gauge die with prior symptoms of failure? Is there something else I should check? Will it work right if I reverse the wires? LOL
EDIT: I forgot to mention that when I touch the disconnected oil pressure sender to ground, the pressure gauge reads MINIMUM instead of MAXIMUM.
