WMO filtering setup
pigpen60
127
foley/missouri
What do yall think about my wmo filtering setup? It has a 5 micron polypro filter then the gearpump and then a 1 micron polypro cored string wound filter out. I plan on using a pp string wound filter on the 5 micron. Whole thing sets on an open top barrel that I heat with a hotplate pressed snug to the bottom for dewatering.100_1451.jpg
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Its not too bad, but you will have issues with the stock O-rings on those housings. When I was using that style I had to swap to a fuel compatible O-ring.
gimpyrobb
27,785
748
Cincy Ohio
I don't have a good answer for you. I took the housing to my local seal shop, told them what I was doing and they sold me a seal that worked fine.
flatheadvff
12
Myra/Texas
where do you find such filters? And about how much do they cost? I know a centrifuge would actually be better, but from what I've read 1 micron should be plenti useable. About how much oil are you able to filter before filter change and how long does it take? Curious as I have about two hundred gallons of wmo, I would like to filter and burn. I have hydraulic pumps I could probably use in making a system.
pigpen60
127
foley/missouri
Like Gimpyrobb said i bought the filter housings at a local hardware store for $22 each and the filters I bought from Mcmaster carr. I dont remember the price but i can say I purchased 10" polypro cored string wound filters. Can't remember why i used string wound, maybe someone can refresh my memory. As to how fast it ran, not sure but i remember thinking that 30 something gallons ran faster than i expected. And on to filter life, I have not hit the lifespan of these filters. I screwed up and did'nt log how much oil I ran through the 1 micron before i bought the second housing and filter. For the o-ring material I will likely buy viton from Mcmaster carr in the appropriate size. The WMO i filtered was heated to 170 f. and let cool and set for 5 days prior to filtering. Hope i hit everything for you.
gimpyrobb
27,785
748
Cincy Ohio
Kipman had a million of the filters(don't remember micron size) for great prices, might try sending him a PM for some.
flatheadvff
12
Myra/Texas
wow quick response. Thank you, now does anyone know where I can get a large supply of "round to its"? I have plenty of time for the oil to settle, as first I need to rebuild my all fuel.
Beyond Biodiesel
37
Prescott, AZ
What do yall think about my wmo filtering setup? It has a 5 micron polypro filter then the gearpump and then a 1 micron polypro cored string wound filter out. I plan on using a pp string wound filter on the 5 micron. Whole thing sets on an open top barrel that I heat with a hotplate pressed snug to the bottom for dewatering.View attachment 634894
I have been using the whole house style filters made by Pentek for about 10 years. I have happy with them, except if you run gasoline-waste oil blends, like I do, then the alcohol in the blend will cause these polypropylene filter housing to swell. So, when you go to change the filter, then you will find the housing will not screw back together, until it has sat in open air for about 6 months. So, I know of several sets of Pentek polypropylene filter housings.
On the type of o-ring to use, Viton is best, because it resists solvents better than other o-ring materials; however, they tend to be expensive and difficult to find. So, as long as you keep the diesel in your blend at or below 50%; and or, the gasoline in your fuel blend down at or below 30%, then BUNA-N is fine, cheaper and easier to find.
