HanksDeuce
- 238
- 63
- Prairieville, LA
Although it was 30% chance of rain all day I headed out to the home of Timntrucks. Tim finished welding up the rear lift blocks, plates, and cross tubes for me. We test fit the M105A2 bed one last time. I marked the patient for surgery. With help from the wonderful XM381.com website I measured the frame cuts 4-5 times and let Tim cut twice.
After all metal work was completed I primed the lift blocks, cross tubes and plates, and the end of the frame that was cut. We removed the rear most bump stops. I need to remove the other bump stops above the jack stands.
Next up is to mark and drill holes to install the rear bumperettes, pintle, and civilian receiver hitch. The deuce front springs should be here soon so we can complete the rear and jump on the front end! I went ahead and sprayed PB Blaster on the pitman arm shaft splines after backing the nut off. I'll try a gear puller next time. Stay tuned for more installments...
#1 The miracle materials
#2 What are friends for?
#3 One last trial fit before marking the patient for surgery.
#4 Marking the M105A2 bed one last time before dissection.
#5 Rear portion of lift kit completed. Frame cut & primed.
#6 Factory bump stops need to be cut. Holes for bumperettes & pintle to come!
