Hub/spindle assembly
nspctr1
San Antonio TX
A few weeks ago I was driving down the road doing approx 45mph when my front rt tire decided to take a detour. From my understanding the locking washer was not installed properly which allowed the bolt to back off therefore letting the wheel to set itself free. I purchased a new spindle as the threads etc were damaged during the removal.
I have a couple of questions regarding this repair. I need the outer seal and am going to replace the other one, are these available at a local parts store? If not, what do you recommend?
Next, Am I correct in thinking that if I remove the 4 bolts holding the shaft in place to the hub that the remaining parts should be laying in the bottom of the hub?
The outer bearing on the spindle looks good, no nicks or burn marks so probably not going to replace it. Question is, how do you get it off?
Thx
ken
24
Houston Texas
I would replace the spindle bearings also. Although it might look ok. The inner race could be deformed a bit. Spindle extraction is normally a violent event. If the inner race is now out of round even a thousands of a inch, that bearing won't be long for this world. As far as finding the parts, take the bearing numbers and the seal numbers and go over to Motion Industries off of 410 just north if IH 410 on the east side. They should have the bearings and seals in stock. If not they will have them the next day. It's normally much cheeper to go to a bearing supply than a auto parts store. Also you can get real Timkin bearings instead of china knock offs.
Retiredwarhorses
3,940
Brentwood, Calif
Thx
it would seem almost impossible for me to believe that the threads on the Spindle fared well....
