Mystery Vision block /door stop😧
Supersonic
Sacramento
Found a vision block at a yard sale. The owner was using it as a door stop but the glass is in amazing shape with no chips or scratches. Trying to find out exactly what type vehicle it was used in. It’s a trapezoid shaped unit with multi layer glass about 4 1/4 in thick. It’s about 9 inches wide on the front and 6 1/2 wise on the rear and about 3/1/2 to 4 inches tall (tapered) and has a part number on one side that is stamped in.
11602005 and also says L.O.F which I think stands for Libby Owens Ford ? If anyone has any info I would love to hear it. I have googled these numbers till I’m blue in the face and can find nothing. 😕
USAFSS-ColdWarrior
Chaplain
5,575
Would love to post a pic but I see no way to do so
In the QUICK REPLY box you will see a tool bar at the top. One of the icons available looks like a picture frame with a black dot at each corner. Hover your cursor over it and you will see its function is INSERT IMAGE. Click on it. The dialog box that pops up is fairly simply to navigate.
We look forward to your pictures to better help you identify this gem.
And by the way.....
Welcome aboard :-D Find a bunk, stow your gear, and prepare to get underway :driver:
