Mine has 16s on it... they're 6.5 wide...I put a 265/75 16 on them and they fit great...from what I've found there's a ford rim out there that is the same lug pattern but a bit wider, I think they're 7 inch...I do think that the one ton gm trucks in 16 inch will fit as well...this tire size was a little taller than what was on it, the stock size and over an inch wider and they fit great.My M1008 has 16.5 wheels, can 16s be used. 16.5 are hard to find in UK
Yes, should have had them stock. Someone changed them over to 16.5sMy M1008 has 16.5 wheels, can 16s be used. 16.5 are hard to find in UK
NoMy M1008 has 16.5 wheels, can 16s be used. 16.5 are hard to find in UK
The ford 16x7 will bolt right up.... and a 255 85 16 will fit just fine with no fender rubbingMine has 16s on it... they're 6.5 wide...I put a 265/75 16 on them and they fit great...from what I've found there's a ford rim out there that is the same lug pattern but a bit wider, I think they're 7 inch...I do think that the one ton gm trucks in 16 inch will fit as well...this tire size was a little taller than what was on it, the stock size and over an inch wider and they fit great.![]()
Yes that's what I wanted but I didn't think a 6.5 inch rim would work well with that...I literally just picked up a brand new Ford set last night...wish I would have known the originals were bent up before I bought new tires!The ford 16x7 will bolt right up.... and a 255 85 16 will fit just fine with no fender rubbing
KM2 255 85 16 on my 86 M1008 on the factory 6.5 wide wheelsYes that's what I wanted but I didn't think a 6.5 inch rim would work well with that...I literally just picked up a brand new Ford set last night...wish I would have known the originals were bent up before I bought new tires!![]()
