Stripped pto gear in spicer 3053 again! Now what
turnerman
13
landrum, sc
years ago I installed a mk17a1 palfanger crane on a deuce chassis with a pto run hydraulic pump. It has served me well except for cold weather days when the oil is cold it will strip the teeth off the pto shaft in the transmission. The hydraulic pump probably pulls 50 hp. Yep you guessed it I forgot to warm the oil up and ruined my trans again but this time where did all the parts go? Now my options seem to be fix stripped gear if can find it, change the transmission to a 5 ton transmission and pto, or find a transfer case pto. Anybody have any leads? I would love the higher hp transfer case pto but I could buy a truck for what they want for the coupling. What do You guys think? Anyone know where I can find the pto gear? Thanks
turnerman
13
landrum, sc
Yes shimmed it twice now I believe the excessive hp is what is stripping the transmission teeth off. It’s a guess of 50 hp. It will bogg the motor down if idling. I’m sure someone knows the pto hp max for a duece vs the transfer case pto?
turnerman
13
landrum, sc
Thanks After seeing the hp is same as motor speed maybe it is the sudden torque of the hydraulic pump that causes gears to strip not horsepower required. I know the weak link is the transmission gear because there is no shear pin in the rear facing pto drive for the pump which has stripped two gears. To clarify the winch is on the front pto drive with shear pin.
gringeltaube
Staff Member
2,364
Montevideo/Uruguay
Guess you misread what I posted from the TM(?) The transmission-PTO (WND-7-28 ) is only 27Hp @ 1000rpm while the transfer case-PTO (P-136-C) delivers full engine Hp.
gringeltaube
Staff Member
2,364
Montevideo/Uruguay
Are you 100% sure that the gear lash was set properly, before these failures?
Even if he had it set correctly; after that much abuse (extended, severe overload condition), the gap between both gears involved (rev. idler- vs. PTO input (driven) gear) rapidly increases due to wear on the respective shafts and roller bearings. Add fatigue and cold temps to it and you'll have the "perfect storm"...
A customer of mine had a log loader crane powered the same way. He came to me after his 3rd catastrophic failure which also included an exploded transmission housing(!) The final cure was relocating his pump in order to connect it to a TC PTO.
turnerman
13
landrum, sc
The best I can recall I followed the tm shiming the pto. I even used blue to look at teeth mesh but that was over 15 years ago so it could have worn. I also used the truck hydraulics one year to plow my fields when my tractor was broken. Highly likely wear but no way to tell when you have shreds. How much do you guys think a complete tc pto will run?
