- 4,258
- 1,713
- Edmond, Oklahoma
Picked up this potable water pump this week.
Brand new and looks to only have been started for acceptance.
They didn’t even paint Unit numbers on this. Just a pump number tape that easily came off.
The 1 1/2” galvanized pipe is included in the shipping crate from factory and was installed and never piped for anything.
The Teflon tape is applied at factory.
The TM is shipped with the pump in the crate but obviously disappeared long ago.
I’m needing the TM if anyone has one.
The TM pictured is a slightly larger pump with same engine.
It’s not in the TM library here at SS.
I also read all the old threads in this
Forum and while several water pumps are discussed, none are relatable to this one.
I’m not sure if I can start this up and run it without water going through the pump.
I’ve read that a garden hose in the intake will work. Not sure and don’t want to ruin it.
Will be getting hoses with quick connections next week or so
Should be a great asset on the ranch and happy it’s Diesel.
Kohler bought out Lombardini sometime ago and parts are still available for this.
I’ve ordered a new Kohler fuel and oil filter.
Also ordered some factory Kohler fuel hose.
Some of the hoses on this unit are cracked from age and sunlight.
Their not plain rubber but some kind of propriety blend.
It’s heavy and definitely not a one person lift. Don’t know exact weight but it’s more than my lower back can handle.
It’s rated at 100db so it’s a loud pump too.
Happy with it so far.
