- 1,161
- 3,975
- Arab, Alabama
I'm sure this isn't the first time this question has been asked. My 72 Deuce has the LDT 465-1C. It normally starts, idles, and runs very smooth. Today I went out to start her up, and she fired up instantly. I noticed that the rpms were a little high, at around 850-900. I let it idle for a few minutes and then tried bumping the accelerator. Rpms increased to around 1100 and stayed there. I shut her down and started searching the forum. My best guess is something in the linkage is sticking. That doesn't explain the slightly high idle, though. Could someone point me in the right direction, i.e. common points that stick and need cleaning? Should I remove the cable and lube it? Thanks for any and all advice.
