- 755
- 1,331
- 93
- Highland, Indiana
It's way cheaper than led complete lights. And looks just like stock. I went with cheap hella knockoffs that didn't fit then purchased the real deal. $35 a piece from Amazon.Mattguy- Looks factory which is absolutely my preference. What did the project end up costing you? Is there any issue finding 24v h4?
HELLA 002395031 HLMP 7" 165MM H4 ECE,2395031 https://www.amazon.com/dp/B005OULUQO/ref=cm_sw_r_apan_i_ET1DACXFCW0X5QN4F5WG?_encoding=UTF8&psc=1
Any h4 led bulb will work, all you need is h4 pigtails to match up with the factory wiring. You can cut wires off old bulbs!
In the listing for led h4's they will show you voltage range. I used these and they are perfect and cheap.
Limited-time deal: OXILAM Mini Size H4 9003 LED Headlight Bulbs, 12000LM Hi/Lo Beam Wireless 6000K White Super Bright LED HB2 Bulb for Car Motorcycle Conversion Kit, Fanless Replacement Bulbs, Pack of 2 https://www.amazon.com/dp/B09HS7499B/ref=cm_sw_r_apan_i_dl_HF50QA15DWDETDSMMCFE?_encoding=UTF8&psc=1
