- 473
- 360
- 63
- California
Ok, so I began to disassemble the turbo, first I washed, cleaned, vacuumed around and behind the turbo and setup a plastic cover to catch any gunk or sand falling from above:
![389FBFCF-EF7E-4FAD-A0DA-FB63DEF213A5.jpeg 389FBFCF-EF7E-4FAD-A0DA-FB63DEF213A5.jpeg](https://www.steelsoldiers.com/data/attachments/645/645323-346e4775e1cece23c34b719bfd9554d9.jpg)
I removed the crossover (taped the intake openings) and it’s coated in oil:
![0789FAD4-276D-4E20-B395-612AFB866011.jpeg 0789FAD4-276D-4E20-B395-612AFB866011.jpeg](https://www.steelsoldiers.com/data/attachments/645/645324-9227583aab11096f76269fcf650a690e.jpg)
I loosened the exhaust and the two collars that come from the two exhaust manifolds and removed the exhaust side turbo wheel cover :
![A9BF988D-E3C9-4309-A133-0250904104ED.jpeg A9BF988D-E3C9-4309-A133-0250904104ED.jpeg](https://www.steelsoldiers.com/data/attachments/645/645325-63a1bb06187429101c100e5686fbec16.jpg)
The wheel rotates easily, but it has about an 1/8” side to side play, it feels like it’s a lot. Isn’t it running on some kind of bearings? If the bearings are compromised, could the exhaust gases make their way into the oil output feed and into the crankcase?
The wastegate seemed stuck, couldn’t be moved in any direction, until I removed the bolt that keeps it attached to the exhaust part, after which it can be moved with a lot of difficulty and it squeaks loudly. It stays in whichever position it’s being set, there is no spring, push or pull or any active response, is it normal?
![D39A86BA-A0FA-4990-A968-7EEDF5CE8D8F.jpeg D39A86BA-A0FA-4990-A968-7EEDF5CE8D8F.jpeg](https://www.steelsoldiers.com/data/attachments/645/645326-0a72f5886bd8e88352654f5a5da4a9a3.jpg)
![727DEA87-F028-4D2B-8748-67B1948CB6A8.jpeg 727DEA87-F028-4D2B-8748-67B1948CB6A8.jpeg](https://www.steelsoldiers.com/data/attachments/645/645327-8058e651a214ed432d0581778cdffd07.jpg)
![B5C37336-2000-4E99-BC48-39198A551FF1.jpeg B5C37336-2000-4E99-BC48-39198A551FF1.jpeg](https://www.steelsoldiers.com/data/attachments/645/645328-5426e44f31e73ea2d366447924b3295a.jpg)
If it’s broken, and it wasn’t opening, would that cause the type of symptoms I have?
I still have to remove the turbo and the two collars are loose but the 2 output sides seem stuck, maybe due to rust. Is there an easy does it method to release the output side or it requires a mallet?
