nairb
109
33
Liberty Hill, TX
This week I fixed a broken generator bracket bolt and installed the upgraded brace that goes to the block instead of the exhaust manifold for the 200amp gen. That thing is heavy, I need to invest in a cherry picker.
Then I installed new 2019 Bajas on 24 bolt wheels, replacing the 2007 tires it came from auction with. Those things are even heavier. Finally road worthy.
Next up will be an airlift bumper and rhino tire carrier.
jake20
840
Illinois
A
Makin me want some 24 bolt wheels for myself heh
Coug
4,162
Olympia/WA
A
honestly, they're a pain. You torque each bolt twice, so for 4 wheels you're talking 192 clicks of the torque wrench. So twice as long to bolt together, and twice as long to take apart.
Only really needed if you're running your truck heavy (over 14k lbs)
jake20
840
Illinois
My most dreaded part is honestly the run flat insert. Ratchet strapping and prying that thing is pretty lame. Makes me wonder if a tire shop could at least handle that part if I bring them the tires and run flats.
Coug
4,162
Olympia/WA
Some are willing to try, but you will likely be paying them by the hour for them to figure it out.
I found if you ratchet strap one side enough to give the runflat a nice curve to it, then use plenty of tire soap, it pretty much slips right in.
I also take the short hook strap piece off the ratchet strap, and run the hook from the longer strap back to that bar. Makes it so you aren't dealing with as many loose ends or odd bulges in the straps while installing.
Removal I use the tree method. Strap tire to tree on two sides, and run strap from run flat to vehicle of choice. I used farm tractor because it's slow and I can see what's happening.
TNDRIVER
436
Cleveland,TN
Bu cutting your strap off so there is just enough to complete the loop and "lock" itself when it is ratcheted it gives you more room on the ratchet to pull it up further. Just my 2 cents.
jake20
840
Illinois
Let us know how that goes.........................................
Oh I’ve already done it a while back, new BFG Bajas on mine. I yanked the run flat out by using 2 trucks pulling apart, similar to @Coug
I just have to do it on another 8 tires soon is what I’m not looking forward to lol
TNDRIVER
436
Cleveland,TN
No No No .......... Getting the tire shop to change them!
Gastrap
153
Central Iowa
They're fun for sure. I used a strap that comes with over-tire tracks for a skid loader. No hooks makes it easy to work with.
Mogman
8,585
Papalote, TX
There is a tool in the 57K0267 tool kit that EVERYONE that owns a HMMWV should have.
I have never tried that tool, I always go with bead locks, maybe someone can comment on that!
AAVP7
261
Dortmund, Germany
You mean that runflat ratchet thing ? I used that several times. Works nicely, and especially the "release" part is way more controlled than with a cargo strap ratchet.
However, I found my runflat tool was bending under stress, so I welded an extra connection into the open end of the "U"-shaped frame.
A friend of mine owns the local tire shop, and we worked on several Humvee tires. Besides the runflat tool, I also used a set of "Cheap Chinese tire spreaders" like these :Ebayde link . Those help to keep the tire sidewalls spread while you fumble the beadlock or runflat in.
My buddy was so fascinated by those tools that he made me leave the tools with him, and I bought new ones. Still a good deal, since we worked with three people a whole day, and he charged nothing.
