jake20
840
Illinois
Either not enough belt or too much pulley! :ROFLMAO:
12469149-3 is too long
12460226-4 is too short
Pulley next to oil filler is offset towards the back and misaligned with the rest
trying to remember which hole the alternator bracket should be bolted through, since the top bracket has 2 holes. That’s my only suspicion as to the belt length issue, I’ve already verified the right tensioner.
TOBASH
3,143
Brooklyn, NY
I’m not a fan, of tan.
Rims were dirty as heck from storage. Washed with water and a scotch pad. Chamois dry and then prep work.
Tedious part is taping off properly. Taping round rims with raised lips has to be done just right.
4 done. Six to go.
Retiredwarhorses
3,942
Brentwood, Calif
Yep, neither of those belts are correct for that pulley….see it all the time.
TOBASH
3,143
Brooklyn, NY
Not quite a HMMWV BUT 1995 Hummer is the 12V version. Same power train.
My 1995 has a Whipple and water injection. Swapped out the PO’s POS 38”x14”wide tires with 24 bolt with 37x12” standard tires just like the vehicle was sold with.
Drives great. Super happy. This is why I painted those tan rims to black.
Next I’ll do the same for my M1025. I’m waiting on my wheel dolly to make the job easier.
I love the military hydraulic jack. Well worth the $360 I paid. Easier than a floor jack. One tip… carry a crow bar or 1/2” steel tube to push the unit down when deflating. Otherwise you need to fight the jack to close back down.
Now I gotta find where the wife hid my black lug nuts. I so love it when she cleans.A2C61A3C-50E2-4B4A-86E6-B1FDDB7B3CCD.jpeg8627735A-28EE-42E0-B9AB-3C0ABAF2813A.jpeg43549FB6-6164-4702-A41C-FFEBB6C4879C.jpeg
osteo16
574
Evansville, IN
4 done. Six to go.
View attachment 901830View attachment 901831
Tobash !! 2 decks of cheap cards woulda done that deal easy peasy....
Mogman
8,589
Papalote, TX
I replaced the last of the original 7K half shafts on the DuraVee today, only 20,000 miles but 30 years old, I guess I can't complain.
As I have said before I use M10-1.5X35 flanged bolts and the larger Nord Lock 1528 washers, these things really cling!
And of course a new seal.
I have been putting allot of miles on the DuraVee without its usual once a month or so ride up on the lift for inspection because the FAV has been occupying that bay.
So I took this opportunity to pull all the wheels to do a tire rotation, service the hubs and give the chassis a good lubrication, GOOD thing I did as I found the Pitman arm is worn SLAP OUT!
Time to grab the TM and order a new one!!
Oh yes the disease continues to progress, I bought another HMMWV yesterday, a 1994 M1097A1 man we are getting out of the Basics and all the way into the A1s!!
It is just a parts rig but I plan on installing that low profile helmet top on the DuraVee after installing AC of course...
I really like the look of the slant backs but you can't beet the helmet tops for leaks etc.
It also has rear doors that is handy as I already have front doors for the DuraVee.
I really like the look of the low profile helmet top over the "standard" helmet top, guess now I will have to get rid of the Detroit, nobody needs two helmet tops
HUMMER H1
748
California
As I have said before I use M10-35 flanged bolts and the larger Nord Lock 1528 washers, these things really cling!
Oh yes the disease continues to progress, I bought another HMMWV yesterday, a 1994 1097A1 man we are getting out of the Basics and all the way into the A1s!!
Very cool
I still have those 7k half shafts at the back, my humvee has about 300k miles
They are starting to make ticking sound.
