M1165A1
- 765
- 93
- The High Country, CO
Ground disconnect if you are killing all power to the vehicle.
Hot side disconnect if you are using it as a power switch for the item, same as any other hot electrical circuit you want to turn off.
For my winch I put a breaker on the hot side. Some people say yes, others say no when it comes to winches and breakers, but I've always put some type of thermal disconnect (fuse or breaker) on every hot wire I add to an electrical system.
Thanks for your view. That bit on hot for the disconnect is what I would have done too but it seems a number of 4WD sites say negative. I am going to disregard that nonsense as internet stupidity.
And I am in the camp of "no" on breaker or fuse. With potentially a 500 A load at peak, I feel like I will trip the fuse/breaker no matter what happens.
