Anti friction tire substance… Medical Ultrasound Gel???
TOBASH
3,131
Brooklyn, NY
Guys, I’ve been doing some research.
It looks like simple water soluble medical ultrasound gel might be a viable alternative to the expensive anti-friction tire lubricant used in our Runflats.
I will need to check compound ratios and if they are ok, but I’m optimistic.
TOBASH
3,131
Brooklyn, NY
IMHO, wire pulling lube doesn't last long enough and runflat lube needs to last.
In many a medical office, ultrasound gel sits for years before use. It is either bacteriostagic or bacteriocidal. I just don’t know if the ratio of “snot” to water is enough.
gringeltaube
Staff Member
2,344
Montevideo/Uruguay
I guess it's a little more complicated than the gel I use for ultrasonic thickness gauging.
Absolutely, yes.......!
Anyone trying to re-invent the wheel by using alternative substances for said purpose should at least read "Point 2 - Prior Art" in the attached PDF-file...
