Mounting H1 AC Condenser vs Universal Coldmaster Condenser
tjonesdfw
64
Coppell, Texas
According to HPG, it appears a factory H1 AC condenser may mount up to the cooling stack on the HMMWV. Can anyone here confirm? Still trying to resolve how to install AC hidden in our center console without adding dual fender condensers. Options thus far:
1. Keep the radio rack and center console we've already built and build our own AC system with an H1 or Coldmaster condenser on the cooling stack with dual fans, and two 22K BTU Coldmaster evaporators hidden in the console. Unfortunately all I've seen anyone do is zip tie the Coldmaster condenser on which I refuse to do.
2. Delete the center console we've built, and just install a single 33K BTU Red Dot in the rear with condenser on the outside of the rear curtain
3.. Delete our radio rack, rebuild the console, and install Restomod Airs' system. Unfortunately they wont sell their fabricated condenser mounts designed for the HMMWV without buying the entire system.
4. Spend a fortune and add factory front and rear evaporators from an 1165 and dual fender condensers.
Mogman
8,546
Papalote, TX
The only thing I can add is it is common wisdom that no electric fans are available that can draw/push more air than the factory fan and adding fans only make the problem worse as it actually restricts flow.
Having said that I have never tried this myself.
I am going the full dual fender cond. route time will tell if that is a good idea or not. :eek:
Mario1600
Massachusetts
intersting info. I’m looking to add AC as well.
I was wondering if the fender mount would
Be a better hidden option. I’m not really liking the idea of stacking another source of heat on top of the oil cooler and radiator.
Mogman
8,546
Papalote, TX
Folks that have that system claim it has allot of capacity, even in S FL, which is almost as bad as being in S TX.
I have an intercooler so I really don't have room for a cond. up front and as you say not really interested in adding to the stack, time will tell, ask me again in June/July :)
