Das_Haifisch
- 95
- 13
- Louisiana
I have pretty much everything I should need minus whatever I'll need from NAPA after my pre-drive inspection. Looking like we'll be taking the initial drive through an inch or so of snow in the O.K. panhandle very, very slowly. I've got about 900 miles to go to Louisiana. The previous owner sadly passed away two weeks ago, he was a Vietnam Veteran named Jimmie. I talked to him briefly before he entered hospice care.
The truck sat for about a year, at least it's been that long since he went on a convoy with it. I know it runs strong and holds air. Given that the chassis has about 40,000 miles, axle health is somewhat a concern -- I'll be picking up GL-5 as needed and doing what I can to not wear them. I honestly don't plan on taking it over 40 until I've got factory new steering tires and am considering disconnecting the rear-most driveshaft once snow is no longer a concern.
I've got equipment to work on the truck, gas cans, water and coolant. Hoping DOT5 will be available at NAPA as needed. I'll be able to afford a service truck should it be needed I believe, but hopefully a wrecker won't be necessary. We will be passing between Dallas and OK city between the 9th and the 11th, assuming I'm confident in the truck. If anyone in the area doesn't mind being an emergency contact, it would be appreciated and compensated if necessary. A special thank you to this forum, and of course, Jimmie.
![IMG_20231218_090551_694.jpg IMG_20231218_090551_694.jpg](https://www.steelsoldiers.com/data/attachments/669/669497-65ef4fde1a9aa9617e518af891dc32b4.jpg)
