- 214
- 62
- 28
- Carmel IN
Hi All, I have a 1984 CUCV and I broke the turn signal lever,. The lever just has the blinkers/turn signal on it and the wiper/washer function on it, no delay wiper, however it would be great if it did. Anyways, I've read some threads and watched some YouTube videos and don't see anything exactly like mine.
Before the lever broke when I turned the left turn signal on it stayed like it was supposed to. But the to get the right turn signal to actually blink I had to hold the lever. I was holding it and I must have been holding it to hard when I broke it. Oh and then the left turn signal blinked just fine but the right side didn't blink. I'm assuming it's a turn signal relay that's causing that because the right side lights did come on. But even the inside on the dash the light never came on on the right hand side.
I do have 2 CUCV's that don't run and I was hoping to get parts off them as needed. I have multiple things going on. I've seen on some videos and I see how to just pull the turn signal lever out, and pull the wire back through the steering column.
On at least one of my broke CUCV's the right side lever stayed on when you turn it on but the left you had to hold it to make it work. I'm assuming that's a different problem?
So to fix just the broke turn signal all I should have to do is get a lever off one of my other trucks and replace the broken lever correct?
I've attached a photo of my fuse panel. I assume the round part is the turn signal relay?
